Cleaning washing door addwash ecobubble
(Topic created on: 14-04-2020 11:06 PM)
NailahJ
Home Appliances
Does anyone know how to clean the door of the washing machine?
Little bits of dust / soap powder / seasoning etc gets into the rim of the door.
It bothers me that something so nice and modern can look "worn for wear" by a small fault.
I dont want to take apart the washing machine door and cant put it back together
May I add it cannot be flushed out with water it amazes me how things get in there
24 REPLIES 24
TessM
Home Appliances
Hi @NailahJ
I would be happy to have a look at this with you. To provide you with the right information, can you provide me with the appliance's model and a picture of the marks?
The model code can be found inside the appliance on a white sticker.
NailahJ
Home Appliances
WW5500 AddWash™ Washing Machine with ecobubble™, 9kg
Top of the doorTop of the doorTop left of the doorTop left of the door
NailahJ
Home Appliances
WW90k5413ux/eu
04y65esj900116p
Is the number displayed on the white sticker inside the washing machine
CarlH
Home Appliances
Hi @NailahJ. Check page 45 of the manual for the best way to maintain the washing machine machine. Hope this helps!
NailahJ
Home Appliances
Thanks for the reply, but it is not the add wash door that collects grains etc.
Its the actual door itself on the outer rim (the clear trimming)
Sarah7683
Home Appliances
Hi I'm also having this problem with mine only purchased it in Jan & I'm not happy with it too. I reported it the other day as it bugs the hell out of me must be some kind of fault.
NailahJ
Home Appliances
Im still waiting for a reply or solution to this.
I haven't heard back from the service agents in a while.
Kat12
Home Appliances
Im having this problem and it is driving me crazy as it looks awful after 1 yr!
Our toaster is abouve washer and all the bits just get stuck in the clear perspex rim design fault.
Wondering if door can be taken off?
ShonaB
Home Appliances
I'm also having issues with this after dropping a bag of flour. The machine is only 2 months old and now looks dreadful.
did you find a resolution?
