Auto dispense problem.
(Topic created on: 16-10-2020 10:37 PM)
Ktxx
Home Appliances
Hi, I have a Samsung washer dryer with the auto dispense function. Up until now it has been working absolutely fine but I’ve noticed that my fabric softener wasn’t loading when it should. I’ve done a drum clean, cleaned all compartments etc and still nothing. This evening I’ve run a rinse and spin to see and have no fabric softener in the machine yet the the dose indicator is showing full when it’s not! There’s also a chugging noise as if it’s trying to dispense but nothing is obviously there (this noise also happens when it was full) I’m at a loss as to what I’m to do?? Has anyone else experienced this?
35 REPLIES 35
Websters
Home Appliances
I am also having the same issue with my 6 mth old machine. Softener auto dispenser not working.... If this is a design fault (which it seems to be) then they can come and take it back!
BrassiestClover
Home Appliances
Exactly the same issue less than 2 years old. Been on to the help people and as I have had a repair i now need to jump through additional hoops to get it fixed. This machine has been no where near as good as previous. The biggest issue is the random long time for washing to take place- can go all flippin day. I really would prefer a fixed time....
andy_in_ireland
Helping Hand
Home Appliances
@Btvcon wrote:
Engineer came out and replaced the entire assembly drawer and housing. The housing which the drawers sit in contains the valve controls at the rear which control when and the amount of detergent and conditioner is dispensed. This has fixed the problem and my machine is now working as new. It would appear that it was not a PCB problem in my particular case.
I have attached the exploded view document I found online which shows the housing assembly and drawers in detail.Assembly Housing.JPG
Question is though in another 6 months is same thing going to happen again - will you have to keep getting an engineer out every 6 months?
andy_in_ireland
Helping Hand
Home Appliances
Our machine WW90T534DAW look at the softener port on the left hand side after just 4 months use! - see how different it looks to the detergent port / seal on the right hand side, thats the problem I reckon, I reckon the autodispense feature works fin with liquid detergent , however there must be something in the fabric softener that the system dont like. Here is another observation, you know these days fabric softeners are very thick, not like the old days when they were runny and these days they say ''concentrated fabric softener' yet in the old days they did not say concentrated and was not concentrated , do you think these days maybe we should be mixing the 'concentrated' fabric softener with water FIRST before adding it to the fabric softener auto dose dispenser compartment so it thins it down and runs through the valve/pump easier and not clog it up? - its just a thought - i might try it next time I add some fabric softener (it will make the fabric softener last longer as well)  Take out your whole auto dose drawer (see owners manual, you have to push down the blue catch on top of the drawer to remove drawer  totally as you are pulling the drawer out) now look right up at the back at the valve ports for the fabric conditioner and detergent - does yours look like this all dirty and blocked on the left hand side like ours?
Jip1000
Home Appliances
Hi where did you get this diagram I cannot find anything online relating to the auto dose pump. Thanks
Jip1000
Home Appliances
Hi where did you find the auto dose diagram I can’t find anything online regarding parts for it. Thanks
andy_in_ireland
Helping Hand
Home Appliances
Gavin3
Home Appliances
Hi Andy, this should help you!
https://almade.es/wp-content/uploads/2019/09/EXPLORADOR-WW10M86GNOAEC-VERSION-01.pdf
The entire pump is part no DC97-19821A. You’ll find it on the Samsung spares website.
andy_in_ireland
Helping Hand
Home Appliances
brilliant thanks
