22-01-2019 08:08 PM - last edited 23-01-2019 09:50 PM
Since today i have receive the final pie for s9 uk btu neverlocked
here is some problmes that i have seen:
-when you try to connect to wifi 5ghz router (linksys wrt3200ac my model) from 10m from another room where the signal is like 2 lines it's stay a long time to connect...never happend on oreo os
-did came back home with 10% battery shut down by itself ..strange .....i have turn it back on manually and still had 8 %...will test again ..but a lot of people are complaning proof :
https://www.sammobile.com/2018/12/28/final-galaxy-s9-pie-update-possible-battery-drain-issue/
-when i started data mobile later in a lose signal even for gsm only restart fix
-also adaptive birgthness is a mess not so responsive
-when you go to settings enter connections lags most of the time when you haven't use your phone ....this never happend on oreo
-also a problem with the wather app when you click refresh on the small cercle enterers the app not refresh ...another thing in the app when you drag to refresh not always works..did clear cache no fix
-samsung internet 8.2.01.2..unable to check for updates . there is no network connection ...retry does not work..i have the latest version ....did clear cache and data no fix
-also when lock the phone some shadow it on the background is there...it fades away ...
we wait so much for this is not finished yet
did perfom wipe cache, full network reset , disable all power savings
what about you ?
25-01-2019 10:03 AM
also a problem with the gallery some time does crash....
25-01-2019 11:45 AM
Thanks @MirceaForce.
Our software team have advised us that there could be a variety of factors going on in each of these issues - and are unable to advise any further at this stage. It's best that you report the issues via the Members app (as you have done) and await investigation and replies from the developers. Sending screenshots and/or videos via Members demonstrating an issue, along with the log files, also helps in the analysis.
26-01-2019 08:12 AM
yes ..did that buy here in my country romania...the answer was from them with 'hey please full reset" i don't know if this will reach to the developers or who is in charge of this
18-03-2019 11:23 AM
i have a post here
maybe you can submit this to the developers ok ?
