04-01-2022 02:57 PM in
Hi,
How do you clean an s9 with a toothbrush?
Thank you.
04-01-2022 03:37 PM in
04-01-2022 04:13 PM in
04-01-2022 06:30 PM - last edited 04-01-2022 06:31 PM
@Dragon21: When you're on a call, have you tried pressing the Volume Up button on the side of the phone, as this will raise the in-call volume. If it's as high as it can go, try the Diagnostics test in the Samsung Members app as advised by @xSteveuk to see if you can hear yourself clearly (this may be called Interactive Checks). Alternatively, head over to your dial pad and type in *#0283#, then select “Start: RCV_1stMic” and speak into your phone like you’re on a call. Can you hear yourself clearly in the playback?
05-01-2022 01:44 AM in
20-03-2022 12:50 AM in
Hi,
Where do I find that link, please?
Thank you.
20-03-2022 12:20 PM in
@Dragon21: Which link are you referring to? If you mean the Diagnostics test, please head to the Samsung Members app > Press and hold on the app icon > Diagnostics > Mic.
22-03-2022 05:07 AM in
Hi,
Where do I find the member app, sir?
Thank you.
