16-02-2021 01:23 AM in
will the S9+ battery fit in and work in a S9?
It has a larger 3500 Amh instead of a 3000 Amh.
Are the dimensions the same?
Will it work okay?
Is there another way of getting a longer lasting battery. My S9 is 2.5 years old and works fine apart from going flat quickly.
Solved! Go to Solution.
16-02-2021 08:27 AM in
16-02-2021 01:11 PM in
16-02-2021 08:35 PM in
Great that settles it
17-03-2021 08:58 PM in
