15-05-2021 12:17 PM in
Galaxy S9 SeriesI thought I would let others be aware that I had a problem on my otherwise totally reliable S9 after the recent software update (installed May 3rd 2021). This is labelled as a March 23rd update in the software information.
Immediately after the update, the battery life went from 5 days to 5 hours!! In fact the phone casing became warm to touch because the processor was working so hard. After a lot of messing about with settings and clearing Apps caches (esp. Google play store) I finally fixed it by clearing the cache partition on the boot-up menu (which is not easy if you are not especially tech savvy).
Now 3 days later, batter life and consumption back to old levels. So just be aware if you experience the same problem as me. Neil
15-05-2021 12:22 PM in
Galaxy S9 Series15-05-2021 12:23 PM in
Galaxy S9 Series15-05-2021 01:12 PM in
Galaxy S9 Series15-05-2021 01:45 PM in
Galaxy S9 Series15-05-2021 02:03 PM in
Galaxy S9 Series15-05-2021 04:26 PM in
Galaxy S9 Series20-05-2021 07:59 PM in
Galaxy S9 SeriesI'm sorry to be the bearer of bad news but this is only a temporary fix and it will start to heat up and waste battery again trust me I've done this on 3 s9 devices now and all have returned to there draining state and repeating the cache wipe does not fix it. I've searched and there is a may 2021 update/fix in the us but it hasn't hit the UK yet 😡
01-06-2021 09:30 AM in
Galaxy S9 Series01-06-2021 09:41 AM in
Galaxy S9 Series
