Support
Open search
Manual macro focus problem
Highlighted
I have the Exynos S9+ and I use the camera a lot, especially macro shots in pro mode.
I have noticed that there is a few centimeters difference in the closest distance that the camera can focus between the manual and auto focus.
With the auto focus or 'tap to focus' I can get as close as about 5.5cm
With the manual focus when dragging the slider all the way down I can only get about 9cm (this distance should also be 5.5cm).
I know it doesnt seems much but when taking macro shots 9cm vs 5.5cm is a lot and it makes the manual focus useless for me.
I have tested this with a friends S8 and both its camera's auto and manual focus modes are having a good close focus distance of 5.5cm.
I have also posted this problem on reddit and it seems only the Exynos models are having this issue:
https://www.reddit.com/r/GalaxyS9/comments/9ex5m3/macro_photography_manual_vs_auto_focus/
Hopfully someone from samsung can help with this.
Here are some images to show the problem:
10 REPLIES 10
Highlighted
Any response?
Highlighted
Anyone?
Highlighted
bump bump
Highlighted
Another bump
Highlighted
Hi, having the same phone and same problem!
Highlighted
Same Phone, same issue.
Seems like a software-problem to me, so it should be easy to fix and patch.
Highlighted
It indeed looks like a software bug. the problem is samsung are ignoring it, i guess because not enough peaple are complaining about it.
I reported about this bug with full details through the samsung members app a while ago and the response I got was that its "normal operation" which doesnt explain why the snapdragon s9 variant or the older s8 doesnt have this issue.
Highlighted
Well at least i can help my self out by using 'Pro' Mode, setting everything to manual as i want and then using autofocus if want to shot very near objects. But it's so sad. The camera makes realy brilliant photos and is hold back by poor developed software.
Highlighted
Yeah, I'm using workarounds too. for example locking the exposure and focus when I want to have a very close macro.
Top Liked Authors
