Support
Open search
Bluetooth connection problems
Highlighted
New Member
Since latest update my device keeps disconnecting bluetooth to my work van
Please help asi pay £6.99 every month for subscription and I'm not getting music on the go
Many thanks
Brian Appleyard
1 REPLY 1
Highlighted
Hey @BrianAppleyard1 ,
that is odd. Can you try these steps to try to get this sorted?
1. Perform a Soft Reset on your phone by pressing and holding the Power, Bixby, and Volume down buttons for 10 seconds and if a warning pops up, press the Volume down button.
2. If the issue persists after that, try to unpair and pair back the device after 5 minutes, If this doesn't work, clear the Bluetooth cache and data by heading into Settings> Apps> 3 dots (top right)> Show System Apps> Bluetooth / Bluetooth Share / Bluetooth Test> Storage> Clear cache and then Clear data.
3. If none of these steps make any difference, speak with your car sound system manufacturer who will be able to check whether the Bluetooth system in the car is compatible or whether it needs updating.
Top Liked Authors
