Battery charge indicator too small
(Topic created on: 2 weeks ago)
JoBaldwin
Please increase the battery charge indicator, or provide a way to manually change it. It’s way too small!! It's great to have the shaded bar but i need to see the percentage too. Thanks.
3 REPLIES 3
Fiona26
Samsung Members Star ★
Things you can try to make it more visible, using widgets, or sending feedback to Samsung. Go to support within the members app, Send feedback.
JAMES4578
Samsung Members Star ★★
@JoBaldwin The size of the Battery 🔋 indicator is a common gripe but feedback (though not guaranteed) may make a difference in he future. There are workarounds though. Here is how one of the widgets looks (I have other stuff from Home Screen on Test Device).
Sonora
Mastermind
And if the widget that James put in is too small for you
