Battery problem
(Topic created on: 26-11-2024 04:00 PM)
sam242p
Hello
Anyone suggest me how can I improve battery health. I moved from iPhone still i got problem battery s24 ultra
7 REPLIES 7
lminvti
Samsung Members Star ★
Hi there 👋
You could try put unused apps to sleep in battery settings
Try wipe cache partition:
Turn off yor phone Connect to PC, tv etc via USB Then press and hold power button and volume up button until samsung logo appears Then quickly release power button and keep holding volume up button until reboot menu appears then navigate with volume down button till wipe cache partition press power button Restart your phone
Check what apps using the most better, try go to apps storage and clear cache or reinstall them.
Batterystat reset:
Open phones dialer Type *#9900# scroll until you see batterystats reset press it 1732637410060.jpg1732637410074.jpg
rosssy
I think that will do
rosssy
And that
BandOfBrothers
Hi @sam242p
There are lots of threads available in regards to how to help with battery.
If you perform a forum search you may find existing threads with some further help or guidence within.
https://www.samsung.com/uk/support/mobile-devices/tips-to-make-the-most-out-of-your-galaxy-phones-ba...
If i can be of any further help please don't hesitate to ask  😎
https://www.samsung.com/uk/support/mobile-devices/how-to-optimise-the-battery-life-on-a-galaxy-smart...
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
GoanGeek
Here. This is all you need.
https://www.reddit.com/r/S24Ultra/s/Cl2IpMUBNp
You can use em all or pick and choose. 😊
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
JerryS
Helping Hand
I think battery health is always going to gradually decline. To help reduce that I tend to keep the battery protection setting at maximum and turn off fast charging unless I particularly need either. Also I charge in the morning while getting ready rather than overnight.
