Sluiten
annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Spring naar oplossing OPGELOST
Oorspronkelijke onderwerp:
samsung S24 ultra ui 7 problems with usb-c earplugs
(Onderwerp aangemaakt op: 24-04-2025 02:55 PM)
136 Weergaven
Members_njNWKZC
Opties
My  usb-c earplugs from sAMSUNG DO NOT WORK ANYMORE  AFTTER UI 7 UPDATES
1 Oplossing
Geaccepteerde oplossingen
Oplossing
Ajay-A
Opties
Hallo @Members_njNWKZC,
Thank you for your feedback about this. I will help you further! Is this also the case after restarting your S24? If yes, you can try to clear de cache of your phone. For this turn of your S23, press and hold the Volume Up and Power buttons until you see the Android logo. After a few seconds you will enter the recovery menu. Select 'Wipe cache partition' and afterward 'Reboot systeem now'. Feel free to let us know if it worked.
With kind regards,
Ajay
Bekijk de oplossing in de community in het oorspronkelijke bericht
2 Antwoorden
Opties
Hello, i think that is a bug
Oplossing
Ajay-A
Opties
With kind regards,
Ajay
