Solution for the mobile data problem
(Topic created on: 15-01-2024 06:36 AM)
Galaxy S 22
Finally, I have succeeded in finding the appropriate solution to the problem of  mobile data  in my phone. All you have to do is replace the SIM card with another one, because I tried all the methods and I did not succeed with any method other until replacing the SIM card.
5 REPLIES 5
BandOfBrothers
Sometimes the sim card itself can fail in many ways so yes a sim swap carried out by your network onto a blank sim card can help @Galaxy S 22
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
As1mi
Pioneer
Im skeptical only because the sim works on another phone without issues
Galaxy S 22
Yes, I was finding the same thing, and when I swapped the SIM card, my phone data came back even though it was working on another phone. Try it, you might succeed .
As1mi
Pioneer
Okay thanks, will try that
As1mi
Pioneer
Update. It didnt work
