Samsung s22+ led view cover PROBLEM
(Topic created on: 24-09-2023 04:35 PM)
Returno255
Hi,
I have a question. Has the led view cover stopped working for any of you ? All of a sudden, it stopped working for me. After putting the cover on my phone, my phone tells me to install the led view cover app. After installing, I enabled everything needed but after knocking the cover, no time is displayed and no incoming notification. I have the latest updates available.
Thank you for all the advice
6 REPLIES 6
Annas1970
Hi. I got the same problem, I noticed that all of a sudden my led cover wasn't working anymore. I thought it could be because a recent update?
Returno255
Hi, I was at the samsung store to ask that if they have any information regarding updates. They didn't know anything so we put a new cover on the trials which subsequently worked. I have a feeling that the flex cable inside broke and because of that the cover stopped working.
Heixmees
Pretty sure that last update UI 6 spoiled that. I have same problem and that happened after lat update.
As there any possibilty to go back on previous version?
Kissmet39
Mine stopped working after the last update aswell
Marcvane86
Pioneer
Heren the same sudden problem only on a S22 (normal) device.
Noticed it the day after the latest security firmware update jan-24 upgrade.
No solution found yet.
MTCS Ltd
My S22 Ultra LED cover also stopped working today. The phone was up to date, and the cover screen was working just fine until today. I can't see any cover view options in settings, nor can I find an app to reset or to uninstall/reinstall. I guess the cover screen ribbon has worn out. But how can I know without buying a new one?
