S22 ultra battery drain
(Topic created on: 13-09-2022 08:42 PM)
weskerevil
Pathfinder
Hi guys has anyone had any battery issues with the latest September patch I've cleared the cache but the 85% battery limit isn't lasting as long 🙄
2 REPLIES 2
Agweyn
Pioneer
Hey Weskerevil,
I had the same issue after one UI5 beta update. Here is what I did
1. Download the Good Guardian app from the Galaxy store,
2. install the Galaxy app booster in it, then click optimise now. It takes like 5 minutes to optimise all your apps.
Hope it helps
Unknown007
Yes. I had it with the fold but they did a software update today and it looks like it sorted
