14-03-2022 11:05 AM - last edited 18-03-2022 12:05 AM
Hi, I'm experiencing an issue with WiFi on S22 . When the phone is idle and connected to WiFi it can't switch to "deep sleep" mode and battery drains much faster then when on 4G.
Is this a known bug ? Does Samsung is working on a fix ? I need to keep the WiFi turned off currently to reduce the idle battery drain, which is pretty annoying. According to multiple threads on Reddit and other sources online I'm not the only one with this issue
https://www.reddit.com/r/GalaxyS22/comments/t7vsjn/my_exynos_s22_bases_battery_drains_34_overnight/
Solved! Go to Solution.
12-04-2022 05:43 PM
Did todays update fix wifi bug?
12-04-2022 05:45 PM
Doesn't look like it.
12-04-2022 06:07 PM
I dont see an system update.
What update are you talking about?
12-04-2022 06:34 PM
I didn't get any update as well.
13-04-2022 03:01 AM
Same problem, s22 exynos no deep sleep on wifi, battery looks ridicolous and it is incredible this big problem which makes the phone pretty unusable hasn't been solved yet
13-04-2022 07:50 AM
It would be nice if Samsung made an official confirmation of the issue. At least here on the forum.
13-04-2022 10:32 AM
A support agent told me an update is meant to be out at the end of this week but no confirmation if the issue is fixed.
The update i received yesterday was weird, no patch notes and seemed like it was reinstalling the one from start of april
13-04-2022 02:23 PM
The bug has been out for a month now and still no fix from samsung...
Yesterday update was only modem
13-04-2022 04:23 PM
I haven't seen any updates not any fixes on this battery drain issue on S22 ! ... anyone hears anything or finds a fix.. please share
13-04-2022 04:58 PM
There is no fix yet. We are all waiting on samsung to fix this. (And confirm this problem)
Also there is a chance it's a hardware problem and it cant be fixed though software.
The best you can do is report an error in the samsung members app. Make sure you include a log after a day's usage (not short after you charged you s22)
