14-03-2022 11:05 AM - last edited 18-03-2022 12:05 AM
Hi, I'm experiencing an issue with WiFi on S22 . When the phone is idle and connected to WiFi it can't switch to "deep sleep" mode and battery drains much faster then when on 4G.
Is this a known bug ? Does Samsung is working on a fix ? I need to keep the WiFi turned off currently to reduce the idle battery drain, which is pretty annoying. According to multiple threads on Reddit and other sources online I'm not the only one with this issue
https://www.reddit.com/r/GalaxyS22/comments/t7vsjn/my_exynos_s22_bases_battery_drains_34_overnight/
Solved! Go to Solution.
31-03-2022 06:37 PM
Does that meen it is an hardware issue?
I am really mad that this update didn't improve anything.
I'm also having lip sync issues while watching video content (YouTube of mx-player etc)
31-03-2022 06:41 PM
Had this too. Go to settings - sounds - seperate app audio - add any app in here ( i put youtube but use YouTube vanced), restart your phone then. this fixed this issue for me
02-04-2022 12:03 PM
Been watching my CPU usage the last two days, seems to now also be at 100% with WiFi off now too. With wifi off i was seeing nornal cpu usage using mobile data. Anyone else seeing this?
03-04-2022 07:33 PM
I have to say the exynos s22 is the worst phone i ever bought: not usable with this bug so its been in box since new.
04-04-2022 02:58 PM
Base S22 wit Exynos. Same batery isues. Worst phone ever bought. Good thing I can still return it, cause it's unusable.
06-04-2022 06:26 PM
Samsung must do an recall of the exynos s22, its an full failure to not fix an bug like this!
08-04-2022 02:10 PM
I'm having same issue, reported today via Samsung members. Hope they can fix this soon.
09-04-2022 12:52 PM
I ordered an Snapdragon S22, sent back the exynos one. Its strange samsung keeps up with the substandard exynos for some markets.
09-04-2022 12:55 PM
@NisseHemma wrote:I ordered an Snapdragon S22, sent back the exynos one. Its strange samsung keeps up with the substandard exynos for some markets.
How did you order snapdragon?
09-04-2022 12:59 PM
Wonda have a few colours of the HK version, same goes for some German retailers (where i get my snapdragon).
Etoren has also the HK and E versions , bit pricey tho
