14-03-2022 11:05 AM - last edited 18-03-2022 12:05 AM
Hi, I'm experiencing an issue with WiFi on S22 . When the phone is idle and connected to WiFi it can't switch to "deep sleep" mode and battery drains much faster then when on 4G.
Is this a known bug ? Does Samsung is working on a fix ? I need to keep the WiFi turned off currently to reduce the idle battery drain, which is pretty annoying. According to multiple threads on Reddit and other sources online I'm not the only one with this issue
https://www.reddit.com/r/GalaxyS22/comments/t7vsjn/my_exynos_s22_bases_battery_drains_34_overnight/
Solved! Go to Solution.
29-03-2022 02:41 PM
What phone? S22 exynos?
29-03-2022 02:42 PM
Yes s22 base model exynos
29-03-2022 02:48 PM - last edited 29-03-2022 02:50 PM
So you have an SM-S901E?, thats snapdragon not exynos
https://www.etoren.com/products/samsung-galaxy-s22-5g-dual-sim-sm-s901e-128gb-cream-8gb-ram
S901EXXU1AVC9 is for snapdragons
30-03-2022 12:37 AM
Hi yes you are correct, and sorry I was confident to say that I had exynos because Singapore always gets exynos.. Apparently this time around this country got a snapdragon..didn't mean to mislead.
31-03-2022 02:33 PM
New update is out, installing it right now. Let's see if it helps.
31-03-2022 02:37 PM
Nice, let hope its fixed, right now my s22 is in box, pretty useless
31-03-2022 02:58 PM
I hate Samsung 😞 Update didn't fix it.
31-03-2022 03:02 PM
No change, it doesn't enter deep sleep on WiFi
31-03-2022 03:04 PM
Confirmed. Useless update for this. 😞 I didn't want to hate Samsung, they made me.
31-03-2022 05:18 PM
Tested with GSI, an non samsung rom
Wifi on but not connected: Deep sleep ok
Wifi connected: no sleep
