Go to solution Solved
S22 Exynos Battery Drain on WiFi
(Topic created on: 14-03-2022 11:05 AM)
Members_eT66blW
Pioneer
Hi, I'm experiencing an issue with WiFi on S22 . When the phone is idle and connected to WiFi it can't switch to "deep sleep" mode and battery drains much faster then when on 4G.
Is this a known bug ? Does Samsung is working on a fix ? I need to keep the WiFi turned off currently to reduce the idle battery drain, which is pretty annoying. According to multiple threads on Reddit and other sources online I'm not the only one with this issue
https://www.reddit.com/r/GalaxyS22/comments/t7vsjn/my_exynos_s22_bases_battery_drains_34_overnight/
Go to solution
124 REPLIES 124
Raverstone
I got my S22 Base Model with Exynos SoC since 3 days. As always i installed accubattery to optimize my battery and i can confirm that my device also suffer from this problem that the device wont go to deep sleep with wifi on. I turned off the wifi and it goes to deepsleep normaly.
This problem drains my battery overnight too like the first poster said. I hope this is a software problem that can be fixed soon.
Members_Xzn7C9C
same issue here, s22 base 128
no deep sleep when wifi is on
im on the latest avcj firmware
hope this will be fixed soon.
Members_4Ajcucw
I'm also owner of base S22 Exynos model.
I see that even in deep sleep state with WiFi off (to be honest all communication like Bluetooth, LTE, sync, etc. is OFF) there is still battery drain problem. In my case 25-30% during the night (ca. 8h).
Disruptor
Unfortunatelly Samsung is still ignoring us (or it is hardware issue, I pray it is not).
NisseHemma
This how it should look like:
(from my S22 snapdragon)
jaly12
Could you also take screenshot of CPU graph from gsam?
Martin851
Fully charged, short call (about 5 minutes) display off most of the time
 but I'm not sure if cpu util is correct in this monitor app
NisseHemma
Any response out from Samsung?
MILNE_RANGERS
I have been keeping a close eye on this thread and appreciate if you can keep feeding back your updates.
I was all set to upgrade to S22 as love the smaller form factor. Although reading this and a lot around the internet I'm thinking in just going for the S21. If the Pixel 6a has wireless charging I will consider that. Coming from a P30 where the battery life is outstanding and even still great after 3 years.
Has anyone had the S21 and is the battery better than the S22?
Cheers
Members_4Ajcucw
I had the S21 and didn't notice such huge battery draining during the night (it was ca. 5% for night) like I have with S22 (almost 30% during the night).
S21 lasts at least 24h on one charging whereas S21 max 16h.
I'm really disappointed with this base S22 Exynos model 🤨
