S 22 Ultra battery issue
(Topic created on: 10-04-2022 09:32 AM)
Hridey Dalal
I'm having problem with my 1 month old s22 ultra sd variant. When i put my phone to charging with it's samsung 45 watt charger it shows that it will charge in 1 hr and when i come back and check after 1 hour its only charged till 54 percent. I didn't understand why is this happening i check all my setting amd even tried it with airplane mode on still its same and tired with 25 watt also still it doesn't charge to the time it displayes. Should i go to samsung service center or do what?
6 REPLIES 6
Kene87
Pathfinder
See if a factory reset will help.
Glenntech
Samsung Members Star ★
Are you using the correct cable for the fast charger. I believe its a different cable to the original one
Could also be a faulty cable
Just double check in settings under battery and device care
Tap on battery and at the bottom, more battery settings
Just make sure the fast charging options are switched on
Hridey Dalal
The cable and adaptor is original i bought them with my phone on the same day. It's 45 watt samsung charger.
They are on from the 1st day still it's same.
Tourbillon De La Vie
Do you have super fast charging enabled in Settings/Battery Device care ?
Hridey Dalal
Yes it is enabled. While charging also its shows super fast charging 2.0
Mobz
Voyager
Charge it whilst the phone is completely off
