01-03-2022 10:44 AM - last edited 02-03-2022 11:25 AM
I received my Galaxy S22 Ultra 512GB, Exynos version, over a week before official release date. As I was using the phone I discovered several bugs with my unit, screen blackouts, occasionaly freezes, conversations loosing sound, phon not reachable over GSM network even if my signals was good. I decided to wait until official release date to see if new software would be released. On the 25th Samsung released new firmware for my phone, and I did a complet factory reset after new firmware was installed. I am now on firmware S908BXXU1AVBF and fresh phone setup.
My screen problems seems to be gone, but GSM network issues are still there. Several times I have been made aware of that my phone can not be reached by callers, even if phone is showing signals. Solution, reboot. Turning on and off flightmode did not help. Also I am experiencing sound dropouts during calls, call is not droped but sound oth ways are lost, duration 10 - 15 seconds. Also when making a call the phone uses much longer time to set up the call than other phones I have had. Calling my self from other phones give simular results, setting up phone calles to my Galaxy S22 Ultra take much longer then calling others.
Have been in contact with Samsung support, but there is no help to get there. Try this, try that, over and over again. I am starting to loose my patients now, and its impossible for me to have a phone I dont know if I can be reached at, and when I manage to set up a call, sound is lost several times during the call.
18-05-2022 03:35 AM - last edited 18-05-2022 03:37 AM
I can have 2 physical sims or 1 physical and 1 esim,eu version s22 ultra,slovakia
18-05-2022 01:33 PM
funny
18-05-2022 05:34 PM
I watched this (https://www.youtube.com/watch?v=kds8-tWASqU) and tried resetting the network settings. Now it's been an hour and no problems. Now I am getting a full signal strength. Also uninstalled and updated the google carrier services in the play store (I don't know does that make any changes)
Please try everything in the video other than sim ejection and hard reset.
Like this, if it works for you.
18-05-2022 05:43 PM - last edited 18-05-2022 05:54 PM
Responding to the idea of switching off and on for 10 minutes to fix signal issues.
Hmm - I hear you and a) I tried it - it makes positively zero difference, b) it's a bit like saying that you can cure cancer by going to sleep and waking up AS LONG AS the sleep is longer than 8 hours..
Bars are representation of signal strength. Relatively unified representation of that across manufacturers - tested with Network Cell Info. Yes they make me happy as long as there is 3+ of them. Coincidentally that also makes my internet speed happy.
Sarcasm mode OFF.
S22 line suffers from two issues: 1) low 4G signal strength (bars *and* dBE), 2) intermittently losing signal. None of that has to do with which BTS you're connected to.
18-05-2022 05:52 PM
Anything Google makes a big difference in how your cell behave, remember Google IS Android and Android IS Google......a bad monopoly
18-05-2022 07:25 PM
18-05-2022 07:30 PM
18-05-2022 07:47 PM
Your Phone from 1993 is not a defective Samsung S22 Ultra. It seams you do not understand the problem(s). And your Phone from 1993 can one thing, some S22U cant: To make a simple call.
18-05-2022 08:19 PM
18-05-2022 08:28 PM
Any one tried to set the network mode to only 2G/3G if the problem i related to 4G and switching between 4G and 3G?
