When I try to place a call using direct call from the edge panel it opens Viber App?
(Topic created on: 04-01-2023 09:27 AM)
ManalFF
Galaxy S21 Series
I open my edge panel and choose a contact to call from the direct call panel. It automatically opens Viber, if I remove Viber it works normally. I can't find any settings on Viber or in Direct Call Panel to fix this issue.
Viber takes over the Phone Call.
Though using the "People Edge" works normally.
any fixes for that issue?
3 REPLIES 3
pete007
Big Cheese
Galaxy S21 Series
Probably because you have viber set as default.
Go into your phone app and make it default, this should override viper.
ManalFF
Galaxy S21 Series
Thank you for your reply, but it is already set to be the default app for calls and not viber.
iliastr
Galaxy S21 Series
Any answer for this problem please..I have 23 ultra
