Go to solution Solved
System UI battery drain on S21 Ultra
(Topic created on: 02-01-2023 03:34 AM)
Dannyboii
Pioneer
Galaxy S21 Series
Hi I have noticed that since updating to android 13, that when I check my battery usage, System UI seems to always be at the top of the list of apps draining my battery. Anyone else have this issue?
BandOfBrothers
Samsung Maker ★★
Galaxy S21 Series
Hi @Dannyboii
Battery stats appear to be on par with Android¹² I was on until Android¹³.
Can you try >
Clear Cache Files from the phone's System Partition Section  > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too.
Daily Driver > Samsung Galaxy s²² Ultra 256Gb in Phantom Black.
I'm here to help. " This is the way. "
6 REPLIES 6
Dannyboii
Pioneer
Galaxy S21 Series
Here is an example. I've also noticed Google play services is always at the top tooScreenshot_20230102_032832_Device care_1000005454_1672630112.jpg
BandOfBrothers
Samsung Maker ★★
Galaxy S21 Series
Hi @Dannyboii
Can you try >
Dannyboii
Pioneer
Galaxy S21 Series
Hi I cleared the cache and repaired the apps and it seems to be better now
Dannyboii
Pioneer
Galaxy S21 Series
Thanks
BandOfBrothers
Samsung Maker ★★
Galaxy S21 Series
That's fantastic news @Dannyboii  👍
Matusov
Galaxy S21 Series
I have also noticed excessive battery drain.  The only solution that worked for me was change refresh rate back down to 60. Motion Smoothing > Standard.
I read that it may stuck at 120 all the time thus the huge drain.
