20-02-2022 12:23 PM in
Galaxy S21 SeriesI got my s21 FE 1 week ago. I have never had a phone before when the battery drain as fast like the s21 fe.
If you are lucky you get 2-3 hours screen on time. The biggest problem is that the battery draining very fast in idle. 10% in 1 hour when in not using the phone.
No matter if im connected to wifi or 4g(dont have 5g connection).
Always on display is off. Brightness on screen is low. Location services is off. I have all my apps in deep sleep mode when not using them. The only thing i do in the phone is browsing the web. No gaming, No video, No audio. I get 7 hours screen on time with my 4 year old oneplus 6t with the same type of daily use.
Anyone else expering bad battery time with s21 fe?
20-02-2022 01:04 PM in
Galaxy S21 Seriesyour battery yet learn how you to use it . If the problem persists, I recommend contacting Samsung / the operator where you purchased it
20-02-2022 04:36 PM in
Galaxy S21 SeriesSame issue here. And iv put almost everything in deep sleep, stopped almost all apps from using background data, restricted almost all apps battery usage, data saver on, 5G off, power saving mode on, dark mode on, switched off wifi, bluetooth location scanning, nfc off, nearby device scanning off, google assistant off, bixby off, sync off, edge panels off, updated all apps on Google store on playstore, bought the proper 25w charger for the phone. I'm basically using a basic phone right now. On standby/idle I will loose 1% every 15mins. I had to do all of this to get to this. Maybe more I may be forgetting something. While my wife's A52 where I just got power saver on .I'm still counting the hours till it looses 1% on standby.
20-02-2022 04:39 PM in
Galaxy S21 SeriesO yeah got mine 3 weeks
24-02-2022 09:25 PM in
Galaxy S21 SeriesSame problem here. When the phone is idle i lose 10 to 12% every hour. Sot is 3-4 hours max. Some days i have to charge it twice
03-03-2022 09:31 AM in
Galaxy S21 SeriesGot the exact same issue. Have had my S21 FE for 3 days now and the drain is just horrendous despite having taken virtually every single battery-saving action that exists. Around 10% drains per 6 hours when not in use whatsoever and that is just...wow. Next week I am going to return the phone and ask for a full refund cause this is just beyond worthless to me. I got a new phone specifically cause my old S8+ battery life was starting to really show it's age but never would I imagine that I would end up with a brand new phone that has a WORSE battery life than my old one.
I've seen some saying that the battery is "learning", but that does not explain then why it has to drain so much just to "learn" and thus I call BS on that.
10-03-2022 01:25 AM in
Galaxy S21 SeriesSo I've still been trying to get better standby time on S21 fe. I've optimized almost all apps on phone. System apps as well to restrict battery usage. Using data saver as well only allowing my favorite apps to work in background.
All this made minor an not always constant improvement. From maybe loosing 1% every 15 minutes to 20 minutes.
The 1 major thing I noticed an switched. I use dual sim. 1 calls an 1 data. But iv noticed that both my Sims are using or trying to connect on 4g network. Even tho iv set only 1 sim to data.
Im not tech savvy or anything. This may be true or not. To try an correct this iv switched my non data sim card to 2G instead of 4G.
Doing this my phone is now constantly more cooler. Whereas before it would be constantly warm.
I loose 1% between 50 to 60 minutes. I'm still resting this theory. If yourl using dual sim maybe check this out. Hope this helps. Don't know if url need to do all my other steps. But changing 2G without doing those steps could help alone.
I just put alot of time to reset phone.
10-03-2022 01:56 AM in
Galaxy S21 SeriesResting=testing.
10-03-2022 11:00 AM in
Galaxy S21 SeriesIRL testing. With moving from one place to another. Network jumping around I'm finding I'm getting about 1% drain every 30mins.
Iv now added "do not disturb" to my arsenal to void drainage on standby. I seem to be getting 1% drainage every 40mins. Iv allowed whatsapp an all calls an messages.
Sucks that gotta go through all of this just to get decent battery life when you not even using the phone.
Worst thing is to wake up to a dead battery which you thought ur 50 or 60% bat life would last the night.
Anyway hope this helps someone who still has faith in this phone. All this still includes everything above my original posts.
So nothings changed since then. Only added.
10-03-2022 11:20 AM in
Galaxy S21 Series Just
