15-03-2023 02:31 AM in
Galaxy S21 SeriesHi, everyone.
I updated my S21 to the OneUI 5 (Android 13) on December 27, 2022. Since that update and the two security updates after that (before One UI 5.1), battery duration dropped significantly, it's lasting less than 50% of what it did before those updates. I waited for the OneUI 5.1 update to see if it would solve it, but it didn't help at all and I didn't change my usage pattern. Can someone look into this? Is there a place where I can submit this for investigation?
Thanks in advance.
15-03-2023 05:44 AM in
Galaxy S21 SeriesYou can send feedback via your Samsung Members app @urielneves
But also look in your Battery and Device Care Section under Battery to see what's using your resources.
Also as a good generic troubleshooting guide also try > Clear Cache Files from the phone's System Partition Section > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too.
If I can be of any further help then please don't hesitate. Take care. 😎
Daily Driver > Samsung Galaxy s²³ Ultra 512Gb in Phantom Black.
I'm here to help. " This is the way. "
15-03-2023 06:09 PM in
Galaxy S21 SeriesI did, she said that could be related to too many apps open and features enabled (but like I said, I didn't change my usage pattern), and they asked me to follow these steps:
1 - To optimize my phone (which I already had done before)
2 - Turn off features I don't use (which I already had done before)
3 - Clear apps cache (done)
4 - Reset apps preferences (I didn't change my usage pattern, and the options I chose before were to save battery for most of them)
5 - Run a battery calibration (*#0228# doesn't work on S21, says "Connection problem or MMI code invalid)
6 - Check battery status through Samsung Members app (the path she mentioned doesn't exists)
I checked the battery and device care section and it shows battery usage for apps of 20%. The other 65% are missing (I use the adaptive battery option).
I did the "clear cache files" thing. However, the information to reach recovery mode is incorrect in the website you pointed.
Thank you for your assistance so far. Is there a place where I can submit this for investigation or someone I can talk to?
16-03-2023 07:08 PM in
Galaxy S21 Series19-03-2023 02:34 AM - last edited 19-03-2023 02:35 AM ) in
Galaxy S21 Series1. They always are.
2. Always had done this way.
3. There isn't a "Good Guardians" app in the Galaxy Store here (I'm brazilian, don't know if this is related to its unavailability). Where is this "Galaxy app optimizer" at, please?
01-05-2023 01:02 PM in
Galaxy S21 Series01-05-2023 07:20 PM in
Galaxy S21 SeriesKinda feels like they did it on purpose to force us switch to a new gen Galaxy S. At least for the 5 years of security updates we should have the phone working at the best performance possible.
