Battery drain
(Topic created on: 09-11-2021 02:32 PM)
ahmed121
Galaxy S21 Series
Battery drains very quickley on one UI 4 beta version. Not good if the problem goes on.
2 REPLIES 2
ironass
Big Cheese
Galaxy S21 Series
Not seeing an undue battery drain on the latest Beta, ZUK1. Certainly as good as Android 11. Perhaps you should check that all your apps have been updated for Android 12 by their developers. Also, did you wipe your cache partition and use Galaxy App Booster after updating?
Please report any findings through the prescribed feedback on the Beta channel of the Samsung Members app.
My device... Galaxy S21 Ultra 5G 16/512GB (G998B D/S) CSC=BTU
GoanGeek
Hotshot
Galaxy S21 Series
Mine has mostly been on par with Android 11 or almost all the beta versions I've had and this latest one has been awesome in terms of stability and performance.
