Samsung One UI 3.0, heat and battery drain fixed ?
(Topic created on: 03-12-2020 08:35 AM)
katarina_sgalaxy_s20
Hello.
 I have Samsung galaxy s20. Like most of you here, I have a problem with overheating and battery. I wonder if a new major One UI 3.0 update will solve this problem?
If not, I'm seriously thinking of leaving Samsung after 10 years of use.  So what do you think, should I stay or should I go?
3 REPLIES 3
RajKot1967
Is it S20 main or S20FE. I had over heating issue with the FE. Have given it back to the service centre after using it for a two days. They said they will examine and get back. More than 24 hours, the Service Centre is still not able to get back on what is the real issue?
It is s20.
In fact I had FE, which I returned due to this problem and took s20 instead but the same thing happens again.I guess the problem is in the phone performance. So I hope new big update will fix it
Arburon
has the overheating problem been fixed after the update?
