Samsun S20 does not recognise ring door bell wifi
(Topic created on: 05-04-2023 12:49 PM)
monirbar
Dear all, has anybody had this problem setting up a ring door bell on a Samsung S20? The videos said that I need to switch off the smart network switch on advance settings, but I can't find it there and neither recognise the ring wifi 😑 any help please
Thanks
2 REPLIES 2
BandOfBrothers
Samsung Members Star ★★
My Ring Doorbell Gen 2 is paired with my Bt Full Fibre Broadband Wi-Fi and works flawlessly.
It's meant to hook upto Home Broadband and not Mobile Data as far as I understand the set up.
I then have the Ring App on my Samsung Phobe what allows me to view my Ring Doorbell Gen 2 along with 2 other Ring camera options too.
It should work for you.
Daily Driver > Samsung Galaxy s²³ Ultra 512Gb in Phantom Black.
I'm here to help. " This is the way. "
AndrewL
@monirbar: Please try swiping up from your Home screen and heading to Settings > Connections > Wi-Fi > Tap the 3 dots in the top right > Intelligent Wi-Fi > Switch to mobile data (Off) > Switch to better Wi-Fi networks (Off).
The 'Switch to mobile data' option used to be called 'Smart network switch' on previous Android versions, so this may be what the instructions are referring to. This would also fall in line with what @BandOfBrothers mentioned about the Ring Doorbell not working with Mobile Data. Let me know how you get on.
