20-01-2022 08:23 AM in
Galaxy S20 SeriesI have problem with the battery after updating to android 12. The battery drains very fast. However, I also have a problem with super fast charging - it is not super fast anymore. I have 40% of the battery, connect it to the charger and it shows that it takes 45 minutes to fully charge. After 50 minutes, I check, and there 67% and 25 minutes until fully charged. After another 30 minutes, the battery is 90% charged. My S20 ultra is slower overall, discharges faster and charges much slower.
I did cache partition. Didnt help at all.
20-01-2022 09:44 AM - last edited 20-01-2022 09:45 AM ) in
Galaxy S20 Series23-01-2022 10:54 AM in
Galaxy S20 SeriesHave you found a fix yet? Been searching for answers in reddit but no luck
25-01-2022 12:55 PM in
Galaxy S20 SeriesHey,
Its not the problem of the apps. I turned off phone, had 15% of battery and then connected to charger. After 1hr when I suppost to have almost fully charged phone I had 60%. Battery draining is so fast that from 90% of battery after 14hr phone have 27%. But in that time I didnt touch phone for 7-8hr. Rest of the time is normal using, some game for few minutes, discord, few phones. Its middle of the day and I need recharg it again.
27-01-2022 08:45 PM in
Galaxy S20 SeriesSame problem I am facing I did update on Jan 24 since then superfast charging is not working same as you mention. Another issue If battery drain completely i.e zero percent charge it took hours to initialize start charging.
28-01-2022 06:00 PM in
Galaxy S20 SeriesSame problem here. After the android update my s20 ultra drains the battery very fast. And charging is terrible slow. Please fix it samsung.
30-01-2022 02:48 PM in
Galaxy S20 Series01-02-2022 12:07 AM in
Galaxy S20 SeriesS20 Fe 5g also having this problem after update. I did notice my phone speaker got a bit louder but my fast charging sia not good
09-02-2022 02:50 PM in
Galaxy S20 SeriesSame for me. Any fixes?
18-02-2022 07:56 AM - last edited 18-02-2022 07:57 AM ) in
Galaxy S20 SeriesI have the same issue, important battery draining with my S20 ultra since last update to Android 12
