27-10-2020 06:48 PM - last edited 27-10-2020 06:52 PM
Hi!
I bought my s20 fe yesterday. It is causing heating issue since start. And battery is draining very fast. It’s exynos version. To check for battery I did a test. I played a already downloaded video for 10 minutes, other then WiFi no extra feature was on, brightness was midway, volume was full, on 60 hz screen refresh rate. It reduce battery from 60% to 55% in 10 minutes. I think 5% for just ten minutes is much. What do you think is it normal ?
as they have said it has a 4500 mAh battery , then at least it should give a little more.
27-10-2020 07:18 PM in
27-10-2020 08:07 PM in
I tpo have this issue
