Problem S20 ringtone problem
(Topic created on: 07-06-2021 06:36 AM)
Engineerlog
Dear My S20 phone keeps turning off the ringtone (( becomes silent ) and I miss calls !!!
It's so annoying .. I miss important calls from work..
Please your support.  I'm a big fan of Samsung..
Please, Don't make me change my mind about your brand !!
5 REPLIES 5
Rob99
Voyager
Do you have a scheduled do not disturb? Or a Bixby routine set?
xSteveuk
Mastermind
On quick settings pull down menu Check that you don't have Do Not Disturb Setting on
Under SOUNDS AND VIBRATION in settings, chose volume then set it to use volume keys for media, see if that helps 🧐
As mentioned above check these settings..Screenshot_20210607-192702_Settings_20121.jpg
RobCarter
Did you get this sorted? I have a very similar problem with my A51 it mutes the ringtone whenever I get a call, txt or message. It is driving me crazy
