20-10-2022 04:40 PM in
Solved! Go to Solution.
20-10-2022 05:01 PM - last edited 21-10-2022 01:38 PM
One Ui 5.1,Android 13 .
20-10-2022 04:52 PM in
@Aminah: If you head to Settings > Battery and device care > Battery, and tap on the usage graph, can you see any apps or features listed here that are using an abnormal amount of battery? If so, you may wish to tap on the app/feature, select 'Limit usage' at the bottom of the screen, and place it in the Sleeping or Deep Sleeping apps folder to limit its background usage.
20-10-2022 08:10 PM in
21-10-2022 01:18 PM in
21-10-2022 01:38 PM - last edited 21-10-2022 02:24 PM
@Aminah ,Good to hear, thanks for confirming.
