So I've just switched over to a s10+ from iPhone x and don't get me wrong I'm loving the phone but to me seems the battery life is pritty poor, sent a few emails this morning and lost 5% on battery life?????
Mine is also 21/02, getting a replacement on Tuesday.
Let's see how it goes.
Have done some more changings in my phone
And here is the results
3.15 hours screen and battery still 60 percent
I used mostly uyoutube and whatsapp
What changes did you make? Share with the group
Install package disabler pro 15.0
Its working for android 9
Disable these unneccesary apps
And use medium power saving mode
U will get 8 hours of screen time
my battery is still 53 percent and screen time is 4 hours now
its been a day left
still i have 53 percent battery
its been a day left
Sounds good buddy but the point I think a lot of people are making is should we have to run off power saving? Should we have to disable things? Should we need to go through a long set up process to achieve stats that the phone should get out the box?
Easy answer is no, sure there are many apps people won't use and can be disabled but we shouldn't need to do this. I can say for sure in my case that 4G data is crippling the battery over Wifi - over two days i've seen the comparison and it's so insane.
In terms of package disabler - did you download this from play store or download the apk? Require root access?
i tottaly understand you
we should not be doing this
this is a serious issue but we got no choice for now
we will have to wait for athentic solution for it
package disabler i download from google
i dosnot need root access
just download package disabler 15.0
or from aptoide app
Hey what operator do you have?
Been discussing this on Reddit and it seems lots of people with EE in the UK are getting especially poor battery performance .
@TimC80 wrote:Hey what operator do you have?
Actually glad to hear this -I'm on EE and on 4G its so bad - wifi with data turned off is perfect - any more details on reddit or link to discussion?
Maybe there are a few operators suffering from the same thing, but there definately seems to be something up with EE
