Why doesn't edge lighting work or there not be an ambient display?
(Topic created on: 03-04-2019 10:17 AM)
ConnorM
I've got a Galaxy S10+ and I've come from a OnePlus 5T. The one major pitfall I have found with Samsung that OnePlus benefited from was ambient display (your screen would wake to show you a notification - only the notification tab though). But Samsung doesn't have this? I wish not to use always on display as I'm afraid it will eat my battery, unless of course if I can get it to knock the screen off while I place it in my pocket or the proximity sensor is covered. Furthermore, edge lighting for notifications seems great and I would love for it to work across all my apps but it doesn't, genuienly only Snapchat appears to work. I've turned on all app notifications through edge lighting as well...
2 REPLIES 2
Colin19
Troubleshooter
Doesn’t work with a lot of third party apps at the moment. Sure this will be addressed soon.:hand-with-index-and-middle-fingers-crossed:
ConnorM
This is good to know it is a case of an update for third party apps. Thank you!
