18-06-2019 07:09 AM
I have a brand new S10 where I restored all my data/settings from my previous phone, an S7 Edge and I noticed the Alarm function to read time aloud is very muffled and not clear at all. All other sounds on the phone work fine, its just this option. I cannot find any setting to change voice or sound for the read time aloud, so seems to be hard coded. This worked fine on my S7 Edge so have switched to using Bixby for now but this feature is not customisable so its a little annoying that you have to listen to all Bixby weather, news etc and the reading on this option is very quick and rushed.
Anyone have similar issues with the clock read time aloud, could this be a bug or just poor design in the clock app?
thank you.
Solved! Go to Solution.
03-05-2020 03:37 PM
Mine is doing that now did you fix yours? Its really annoying
07-05-2020 03:31 PM
The change in how the time is read out was so annoying! I found a fix by following the other guys instructions to text to speech, change it to Google speech then go into the settings there and there is an option to turn off Numerical processing, which affects how times and data are read. Once you switch that off it goes back to normal.
07-05-2020 10:40 PM
thanks @AB_25 , that got rid of the annoying colon
