09-12-2020 09:22 PM in
Galaxy S10 SeriesOk folks , I put my S10 on charge every night and I turn off WiFi , mobile data , Bluetooth and the always on display but the phone stays on , after it reaches 100% I take it off charge around 2am , by the morning it will have discharged by about 8% !! Is that about right considering there's nothing turned on ?? What are anyone elses discharge rates ? Thanks
09-12-2020 09:35 PM in
Galaxy S10 Series09-12-2020 11:41 PM in
Galaxy S10 SeriesI'll check in the morning , tbh I don't device care provides much info
10-12-2020 12:02 AM in
Galaxy S10 Series10-12-2020 12:15 PM in
Galaxy S10 Series10-12-2020 02:35 PM in
Galaxy S10 SeriesWell I've disabled background data in all apps and it looses about 1% per hour on standby , better than it was but still not right
10-12-2020 03:16 PM in
Galaxy S10 Series@Edgie70: That doesn't sound too alarming, however did you notice any apps listed in Settings > Device Care > Battery > Battery Usage that are using an above average amount of battery? In the meantime, although I appreciate that you have already attempted some of these steps, please check below to find suggestions on how to improve your overall battery life.
- Shut down all background apps when not in use via the Recent Apps button
- Turn off Wi-Fi, Mobile Data and Bluetooth when not in use
- Enable Power Saving Mode: Settings > Device Care > Battery > Power Mode > Select Medium or Maximum Power Saving, or Adaptive Power Saving
- Reduce your screen brightness.
- Change the screen refresh rate form 120hz to 60hz
12-12-2020 03:23 PM in
Galaxy S10 SeriesHi , I installed accubattery and it didn't show anything alarming and phone goes to deep sleep for just over 7 hours , interesting that it showed my battery as 3400ma but was actual 2800ma ! Is it that worn after 20 months !! I did a test and browse Facebook with white mode and I got 3min 49 seconds before it dropped 1% on dark mode I got 5 minutes before it dropped 1% !! I'll keep on dark mode but tbh a phone like this with a 3400ma battery is not great , should've been 3900ma minimum I think , cheers
13-12-2020 10:16 AM in
Galaxy S10 SeriesUpdate , put phone on charge last night before bed but this time I turned the phone off , took it off charge about 3.30am and when I turned on the phone this morning about 9.45am it was on 100% !!! So I think it's this awful Samsung Exynos chip problem with signal !!! Phones been on about 30 minutes and I'm typing this out and it's now on 97% !!!
