Battery LED indicator
(Topic created on: 20-07-2020 11:17 PM)
HalaPhilip
Hi,
Suddenly the red  LED indicator stopped to appear while charging. I checked the settings and it's toggled on.
Anyone else having this problem?
ChrisM
SuperStar
No problem, @HalaPhilip! Glad you got it sorted!
3 REPLIES 3
ChrisM
SuperStar
@HalaPhilip
Is the software on your phone up to date? Go to Settings > Software update > Download and install. Also, let's try a soft reset on the phone. This will end all processes and give the phone a fresh start. Press and hold the Volume Down and Power keys at the same time until the phone switches off and back on again.
Let us know how you get on!
HalaPhilip
Thank you @ChrisM
I think my phone is haunted (lol). As the issue started out of the blue, it just ended the way it started.
Thanks again.
ChrisM
SuperStar
