Fingerprint scanner Problems post updating to UI 3.0
(Topic created on: 22-12-2020 05:31 AM)
Dman1111
Galaxy Note20 Series
Anyone having issues with their fingerprint scanner post update? I can't explain it, when I first updated to UI 3.0 the other day my fingerprint scanner worked better than ever. Now all of a sudden today it like it can't read my fingerprints at all. Keeps telling me to press harder and doesn't register very quickly. Worked great for the first day after install of the new OS.
5 REPLIES 5
BandOfBrothers
Samsung Maker ★★
Have you tried deleting the fingerprints and re setting them back up @Dman1111
I haven't updated to Android 11 and Samsung One Ui 3.0 yet so can't check.
However Go into Settings . Biometrics and Security.  Biometrics Preferences . Turn Off Screen Transition Effect.
Then go into Settings and search for Optomise Battery Usage. Tap in Optimise  Battey Usage  tap to show All and scroll down to com.samsung.android.biom and toggle Off
For me this improved the fps on my Note.
Daily Driver > Samsung Galaxy s²² Ultra 256Gb in Phantom Black.
I'm here to help.
Lykia
Hi, you could try resetting the biometry app.
This had worked out back when I had my S10.
Give it a try, doesn't cost anything. 🤪
Settings》Apps》Filters》show system applications》com.samsung.android.biometrics.app.setting》Storage 》Clear Data
ᐯIEᒪE GᖇÜßE, ᒪYKIᗩ
unsfalcon
I have such issue, fingerprint works much worth than in one ui 2.5. Accuracy is bad now, i ve done full wipe, registred fingers again, it didnt help
RichG
yep not working at all!!
WeiHan
i have same problem after update to ONEUI3. now the FP not usable at all.. try to reset everything still the same. Problem is my unit is HK ver, and i am and Malaysia, Samsung service center Malaysia not entertain oversea phone even i want to pay for repair the phone, which i find it absurd. like the phone will become junk if anything happen outside the country you bought from.
