Camera sound (or a sound) when moving phone
(Topic created on: 21-08-2020 10:07 PM)
jn_shelby
Galaxy Note20 Series
Hello, just received my phone and it makes a sound like something is not well connected, wanna know  happeningif is normal camera sound or it is a fault,  is it happening to you?
3 REPLIES 3
fonix232
Pioneer
It's perfectly normal. The OIS part of the camera is "loose" when the camera is not in use. You can test this. Shake the phone and you'll hear the rattling. Then open the Camera app, and shake again - the noise should be gone. If it isn't, contact Samsung directly, as that's a fault in the phone or the camera.
BandOfBrothers
Samsung Maker ★★
A few of my phone's have had the same noise you speak of and to be honest I've only ever noticed when someone wrote about it on a forum :smiling-face:
It's a normal part of the camera so please try not to worry about it and enjoy your phone.  :smiling-face:
🌈 Stay Safe & Stay Alert.  🌈
Current Phone > Samsung Z Fold³ 5G. > Software : Android 12 ~ Samsung One Ui 4.
Anonymous User
Not applicable
if it is the note 20 it is the ois of the main sensor, if it is th ultra it is also the moving part of the periscope.
All this sounds should disappear or be reduced if camera is being operated
