A35 Unresponsive Power/Side Button Help
(Topic created on: 07-02-2025 04:32 PM)
Anonymous User
Not applicable
Hi guys. Anyone else experiencing this? I just bought the phone a few days ago. It works half the time and sometimes doesn't. You have to wait a little. Same when I tap the screen, the double tap to wake the screen, doesn't work when power button doesn't work.
Please help. Thanks.
3 REPLIES 3
BandOfBrothers
Hello 👋 and Welcome to the Samsung Community Forum @Anonymous User
Try a forced reboot by holding down the volume down key and power button simultaneously for more than 7 seconds to restart it. When your phone resets, you will feel it vibrate.
And Safe Mode  > https://www.samsung.com/uk/support/mobile-devices/how-to-start-my-galaxy-device-in-safe-mode/ turns off downloaded apps and themes etc which may highlight an app or theme that's causing conflict. Alternatively long press the power off button and then long hold on Turn Off to get to Safe Mode.
Last resort is to back up and factory reset.
However as the phone is new you shouldn't have to be carrying out troubleshooting steps.
Consider a swap out ynder any relevant cooling off period.
If i can be of any further help please don't hesitate to ask  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Anonymous User
Not applicable
Hey B.O.B. Thanks for your response. I'm going to try these and get back to you with how it goes. Thank you. I hope you have a good day.
Jennico
Thank you so much! Gemini brought me here. Your 7-second forced reboot worked like a charm. I was trying a reboot since 12 hours but I guess for less than 7 secs as the Samsung logo never showed up. Now finally it's working again 🙏🏾
