Camera Assistent doenst work with Expert Raw
(Thema erstellt am: 28-01-2025 08:21 AM)
34 Anzeigen
BariSavage
camera assistant crashes when I access the setting via expert raw Camera assistant crashes when I click on the "gear" setting via expert raw. Data caches were reset, didn't help.
1 Antworten
PatrickB1
Beta Moderator
Beta Moderator
Hi @BariSavage ,
thank you for pointing this out. If this problem occurs again, please create a detailed bug report in Samsung Members Beta via “Beta Feedback” and don't forget to attach the log files. Then our developers will analyze this problem and hopefully find a solution as soon as possible.
Best regards,
PatrickB1
