Battery drain
(Topic created on: 02-08-2025 09:43 AM)
amaan9082
Anyone else noticing battery drain after beta 4?? I am getting 4 to 5 hours only now. Which is really bad compared to beta 3
5 REPLIES 5
weskerevil
Helping Hand
Have you cleared the cache and run the galaxy app booster it helped mine
Stevo-007
Navigator
Hi I here have not really noticed, any vast change in battery uses.
The same more than a days usage, birding on 2vdays usage, if used lightly. HIH. S
AlexLeeds
Navigator
To the contrary, my battery seems much improved on Beta 4 S25 Ultra over the previous betas
NaughtyButNice1
Pathfinder
If you don't have it already I found downloading Good Guardians by samsung from the galaxy app store is particularly good for keeping the device running smoothly there are tool to look at battery temp and app booster to keep samsung device running smoothly.
AnnaMaz
Beta Moderator
Beta Moderator
Hello @amaan9082,
I appreciate your input! Please also send an error report through the Samsung Members app to help the team understand the issue.
