Adaptive power saving doesn't work
(Topic created on: 08-12-2024 03:13 PM)
Uzoma
Voyager
I have it on and my phone gets to a low battery percentage without power saving coming on throughout my entire drain from 100%
Also, my battery drain is noticably worse on one ui 7 compared to 6.1
2 REPLIES 2
Griffa87
Can't comment on your particular finding, but I find my battery lasts the same if not better in this new build. Using same settings I was in previous OneUI. Hope you find a solution 🙏
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Uzoma,
Thanks for reporting! Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause 🙂
Have a good day!
