samsung G9 oled upper right corner flicker
(Topic created on: 27-04-2024 01:49 PM)
Salohcin
您好,我有一台三星G9 oled显示器(型号为 S49CG95),在使用过程中我发现切断信号输入后,黑屏右上角会出现一个白色方块,只有刷新时才会出现此问题速率设置为 120hz 或 240hz。
https://youtube.com/shorts/ayDcDWV8Kxw
https://youtu.be/xN8wQC0ALCA
2 REPLIES 2
Salohcin
When the refresh rate is set to 60hz, the problem does not occur. I am using a dp cable.
JAMES4578
Samsung Members Star ★★
For the benefit of others, translated as follows:
Hello, I have a Samsung G9 oled monitor (model S49CG95). During use, I found that after cutting off the signal input, a white square will appear in the upper right corner of the black screen. This problem only occurs when the refresh rate is set to 120hz or 240hz.
Videos still to be approved by Moderators.
