monitor issue or firmware?
(Topic created on: 19-10-2024 09:16 PM)
Shamanji
Hello i got my second monitor a Samsung Odyssey Neo G8 Qled Mini Led 32 Inc 240 Hz, the first one was faulty and the second one also faulty but it got a the va panel changed and the corruption is gone.
But when i power on the pc and just before it post when the displayport logo appears in the top left corner it dos it blinks once like the mini leds in side is doing it.
When i then power the pc off and the monitor goes on standby it also blinks again.
Samsung Odyssey Neo G8 Qled Mini Led 32 Inc 240 Hz.zip
i recorded a video file of it its on my one driver to download i hope any of you can cast some light on what it is or if i should get it in for repair again or its firmware related.
it tried using 3 different display port cables with luck and 2 different pc's still the same.
It even dos it i unplug the dp cable from the monitor and power it on or off.
i hope someone here can shed some ligth on it :smiling-face:
2 REPLIES 2
Shamanji
Anyone?
Shamanji
