Go to solution Solved
UE49MU7070 & HW-MS650 soundbar low volume problem
(Topic created on: 07-08-2017 10:21 AM)
Dtag
Audio & Video
Hello,
Last week (1-8-2017) I purchased a new UE49MU7070 and HW-MS650 soundbar after reading all the great reviews the soundbar had.
I have the soundbar connected via a HDMI cable connected between the TV and the soundbar (using the ARC compliant HDMI port on the TV)
I have found though, that the output volume is not what expected when using a signal derived from the TV (satellite program from internal TV decoder, Netflix app on the TV, Youtube app on the TV, etc.). I can increase the volume to 50 and the sound level increases as you would expect, but from 50 to 100 the level hardly changes, and even at the maximum volume the sound level is not what you would expect from a 180W soundbar, infact it is still quite low.
Now I know it is the TV that has the audio problem and not the soundbar for the following reasons:-
1. If I use the TV speakers instaead of the soundbar, I still have the problem with volume increasing OK up to to 50 level, but from 50 to 100 there is hardly any increase.
2. If I use the spotify app on the TV, the sound level does go loud. If I play the sound from the soundbar the sound goes really loud (just like all the reviews say it does)
3. And this is the real test that shows it is a TV problem. I also have an X-Box one connected via HDMI to the TV. If I play a movie from Netfilx on the X-Box the sound from the TV/Soundbar increases normally all the way up to the max 100 setting (and sounds great!) as soon as I swith over to the Netflix app on the TV the sound level drops dramatically, proving beyond doubt that it is the sound level coming from the TV that is the problem.
The TV has the latest firmware, and I've gone through all the sound settings on the TV but I can't find anyway to fix the problem. I've found other people complaining about low volume from the soundbar on the internet, but I think it is the TV and not the soundbar that is the problem, I am assuming that all the people who are complaining have the soundbar connected to a Samsung TV.
Has anyone else come across this problem or does anyone have anything for me to try before I take the TV back?
Thanks
David
3 Solutions
DanBrady
Audio & Video
I'm not sure whether this will help however I have just bought a mu6200 and the sound on day one was fine but after that it's been really low. I've had to have the TV set to 100 (maximum) and even then it was difficult to hear things and not as loud as it should be on maximum.
I tried to change all kinds of settings and no luck, the sound from the menu selections were really loud when volume was at 100 so I knew the speakers were fine, but every other source of volume output on the TV was poor.
I have a galaxy S8+ and when I swiped down on the phone to access quick menu I noticed "Samsung connect" with my TV showing as connected. I selected the TV and chose 'mirror view' .The volume shot up instantly and now I have it set at 16 as opposed to 100
May not help but just incase I thought I'd offer my fix...good luck
EAGLESFAN
Audio & Video
Hi. I had the exact same situation. We found that by going into the settings menu in our cable box, under audio, you can change from stereo to Dolby. Then in the sound settings in the tv, go to expert settings/digital output audio format and change to DTS Neo 2:5 and that solved our problem. We were in the EXACT same position. Now all tv,movies,apps etc. all sound incredible.
Hil2018
Audio & Video
just signed up to provide a solution that worked for me.
This is what solved the problem. i have a Samsung TV 40" and a soundbar Samsung HW-MS651.
very short answer: TV Ouput should be set to Dolby Digital instead of PCM (eventually other formats)
the problem is the TV ouput not the soundbard. After ajusting the settings (which are sometimes reset for unknown reasons), the sound is suddenly becoming very high, and all related (movie) effects were sudenly distincly very audible
here is what you have to do (of course loook for similar menu in your TV, should be similar):
1.jpg2.jpg3.jpgenjoy!
take care
Naoufel
60 REPLIES 60
Dtag
Audio & Video
Seems like Samsung have a serious problem with the way they are outputting the audio level from their TV's
Seems others on the SONOS forum are having exactly the same problem as me (see link below), but with different TV models, which make me think it is a system wide problem, and makes it pointless connecting an external sound device to a Samsung TV if you can never get the maximum volume from it.
https://en.community.sonos.com/home-theater-228993/samsung-one-connect-low-audio-volume-6788665
I'm confident that I could reproduce this problem on any recent Samsung TV to their engineers if they are interested.
DanBrady
Audio & Video
Parksy83
Audio & Video
DanBrady you have just saved my life! Just tried the fix with my S8 and it worked! Been going mad for the last week! Thank you
DanBrady
Audio & Video
No worries. I realised after ordering a sound bar 😂still have No idea what caused it or why connecting with the phone resolves it but hey, if it works....
R22GDW
Audio & Video
I've just encountered the same issue, but I don't own a galaxy s8, iPhone user. Any ideas how I can resolve this?? I connected via BT using Spotify and volume is amazing, but I'm suffering terrible volume when connected to TV as you deceive above
DanBrady
Audio & Video
Sorry buddy, I do not. I honestly dont know what I did when I connected my phone but it made a huges difference. I was convinced I had a defected unit until I stumbled on the fix. Try turning everything off at the wall and reconnecting as that has fixed a few issues for me -  good luck
R22GDW
Audio & Video
Disconnected/reconnected and working fine now, very strange indeed. Volume fine day one, dropped, and now only sorted by rebooting, hopefully doesn't happen again. Ta
tomfree
Audio & Video
This is unbelievable. After several hours of troubleshhooting my extremely low tv speaker volume issue I stumbled upon this post about the cell phone mirror option and WOW , it worked.Thanks for sharing. FYI when I first tried the mirror option I had my phone mirrored onto tv and that did nothing but when I switched to having tv mirrored onto phone the volume on tv came back to normal. Crazy!
DanBrady
Audio & Video
Glad I could help. I didnt intend on  hijacking this post but this appears on Google near the top when searching for the issue so thought I'd try to help anyone else in the same boat as me
