05-08-2020 02:00 PM
- Mute
- Highlight
Hi there,
Now that the SWA-700 is not sold across the usual outlets in the UK, does anyone know what other wireless sub woofers from Samsung may be compatible with the HW-MS750 soundbar?
thanks
J
18-11-2021 11:19 AM
- Mute
- Highlight
Did you ever find out an answer to this question? I have the exact same HW-MS750 soundbar and would like a compatible sub woofer to compliment it. What other sub woofers would work here?
18-11-2021 11:40 AM
- Mute
- Highlight
Hi, afraid not.. I managed to buy a new SWA-700 on line from the UK Currys store on Ebay as an end of life product sale, so worked out well.
sorry I cant help, but the above unit is worth sourcing if you can get it any where..
18-11-2021 11:45 AM
- Mute
- Highlight
Ah okay, thanks. I'll keep searching. I've only found pre-owned ones so far. There must be a retailer out there with a SWA-700 gathering dust somewhere. Just a shame that other subs wont be compatible with the MS-750. I'll get there I'm sure....thanks again
