22-10-2019 01:32 PM
Resetting works for a bit then just keeps going back to the red and blue blinking light
14-04-2020 11:08 PM
It connected about 10 seconds the way I followed the user's manual but still disconnected after 5-10 seconds and the blue and red light blinked again.!
24-05-2020 05:28 PM
Hii,
Anyone find an solution for this strange problem?
Regards,
03-07-2020 02:15 AM
Hello friends, anyone resolved this issue? I have WJ7501 curved soundbar since about 6 years and it was working good until this morning when solid blue light turned blinking blue and red. Re-connecting helps for seconds, the main unit and subwoofer are next to each other, I even place them directly next to each other. Would updating firmware help?
07-07-2020 06:51 PM
Did some get an unswer to blue blinking screen
20-08-2020 09:01 PM
Hi,
The same problem here. I updated the firmware, not solves. So I plugged in the power cable from the subwoofer to the same switch with the main unit. Now its closer to the main unit. Works for me. Red Light isnt flashing. Maybe its work
Best regards
05-01-2021 12:19 AM - last edited 05-01-2021 12:22 AM
This is a very shi*ty problem.
I spent 500 USD in a HW-Q70T soundbar + rear speakers and it happens a lot.
After many hours lost trying different things, what seems to work is to unplug the TV from electricity (Soundbar still connected). Disconnect subwoofer from electricty. Wait 10 seconds. Connect subwoofer. It will link to soundbar (but no sound since TV is off). Then turn on TV, and the subwoofer remains linked.
12-01-2021 10:02 PM
This is a very annoying issue - my Samsung R7 speaker flashes a blue light, then a red light - and constantly loops - it does not connect with any device! Anyone resolved this or know what is causing it?
12-01-2021 10:06 PM
It turns out it wasn't the workaround. I don't know what a workaround is for this.
Sometimes it won't connect. Then I unplug everything and let it rest for 10 min then it connects the subwoofer.
Could this be related to current voltage? idk... I don't know what else to think of
28-01-2021 12:10 PM
Hi, I finally got some help from Samsung. Their audio engineer said its a fault with the main PCB and this part is no longer available...basically it's useless now!
21-02-2021 02:00 PM
Hi did anybody find a solution. We have exactly same issue with Samsung soundbar hw j6500R
