How to control and install increasing ringtone sound on S8+
(Thema erstellt am: 01-01-2018 08:20 AM)
801 Anzeigen
amb
I've got a Samsung S8+ and I don't want to ring out all people arround me only because of that I am very often in a very loud place. So I want to get it working in the way that it starts with a low ring and increases this over an adjustable time to a high ring. If I would programm it I would do it that way from volume1 to volume 2 with changing_time because that will give everybody what he ever will need. Maybe a loud start and decreasing or a low sound at the start and after 10 secs a loud one. However this works it would be the finest way for every user to define this time setting by himself and the two volumes so that is what I am serching for, but I want to use it from very low sound to a louder one each time it rings.
Hope I did asked this question that everybody is understanding what is my problem. I think on older phones this was easy to get but not really adjustable.
Best regards
Andreas Bartels
1 Antworten
AuraK
Hallo amb,
ich antworte dir mal auf Deutsch. :smiling-face:
Aktuell ist die Einstellung, die du dir wünscht, auf dem Samsung Galaxy S8+ nicht möglich. Gern gebe ich die Idee aber an unsere Entwickler weiter.
Viele Grüße
