19-12-2019 01:12 PM in
Hi all.
I have a gear S3 Frontier and it seems like the watch has to places "just so" on the pad to charge, and even then, it sometimes will revert to flashing the led on the charger, when thebwatxhbhas not moved!
Has anyone else seen or experienced this?
I have the correct wall charger and cable that came with the Duo.
Oh and is that opening below a fan?
And if so, should we hear it?
I hear nothing.
Thanks!
03-01-2020 03:29 PM in
Hi, no one replied and no, not sorted and purchased from best buy, why
03-01-2020 04:27 PM in
As this is classed as an accessory, if you think the product is faulty, the resonsibility would rest with the retailer. Have you spoken to them directly?
09-01-2020 07:53 AM in
My one does exactly the same thing.
03-06-2022 06:33 PM in
same thing . charges for a few minutes and stops charging and the red led blinks.
