Go to solution Solved
Duo Wireless Charger Flashing Red lights
(Topic created on: 13-03-2019 06:41 PM)
Swampmeister
When I plug in my charger, using the provided plug and cable, the 2 LED lights flash green, amber and then red.  The lights continue to flash red and nothing will charge when placed on the unit.
I have tried numerous sockets and different combinations of plug and cable without any change.
Does anyone have any ideas?
Go to solution
44 REPLIES 44
CarlosAyalaS
Do you know where i can buy the correct charger for my duo? Or what should check for to make sure is the correct one?
Swampmeister
@CarlosAyalaS wrote:
Hello, i have the se problem u had, but i dont have the original plug, by any chances could you take a photo of it? In the output of the tall one says 12v?
Here's a couple of photos of my adapter.
Still working since my solution
FCastle1
Would you happen to have a link to where I can purchase a replacement charger cord and plug?
Swampmeister
Sorry I don't work for Samsung (or one of its suppliers).
It seems as if the charger is highly specific - if you have lost or broken the original you may well be screwed
Perhaps someone from Samsung can confirm or help
CarlH
mikefearn83
Hi.
I'm trying to find a charger for my Gen 1 charger duo. I purchased a EP TA800 25w superfast charger, but it will not work. Instead of flashing red lights, I get flashing green then red which continues to repeat.
Any idea or is it just the TA300 which will wor .
Geoff0623
mine is about 2 years old and it's always connected to the outlet. it just started to flash red light continuously. It's connected to the correct charge brick. it's supposed to last longer than 2 years why it's like that? can anyone please help?
Brian19
Did you ever find a solution to this? I'm having this red then green and repeat flashing issue and I can't figure it out. Thanks
Swampmeister
The solution is at the top of this thread - use the correct plug!
ButchN
Dude, if you bothered to read, there are people like me who USE THE CORRECT PLUG, yet still get flashing lights.
